aftermarket CDI
tsunami
cdi is not realated to tps guys... Tps funtion works when cdi is plug in...tps also make out bike run in good timing but without tps 1135lc can run more fast
medangmru
ust asking and hope get anwer from the expert here.
What is the bad consequences on having aftermarket cdi installed in our bike without changing the other part of the engine Ie: Racing cam /Valve Spring and bigger block.
Some says that it would harm engine which could not accept accelerator/top speed made by the aftermarket cdi......my friend who installed the brt Adjustable I-Max cdi encounter problem with his engine after 2 month using those cdi .
TQ in advance for your help...
charge
medangmru, if the firing angle advancement is too huge, it may cause knocking at low rpm, thus harming the engine.
HELP NEEDED:
I am wondering if TPS is still working after using BRT dual band CDI. The diagnostic light seems to blink away real fast when I turn on the electric.
Besides this, for dual band CDI, it says the difference between band I and band II is 2 degree. Let's say I set to 35 degree, when the switch is OFF, it is 33 degree, and when i turn ON, it is 35 degree?
kamalez
That where if you are using the programable CDI not to adjust to advance to gain pick up. It will harm the engine as is you are still using all parts
naije82
hello guy i just wondering can kitty xbox cdi plug-in with stock cdi..like xp..that using 2 wiring cdi....
thanks a lot i just want to,....
:roll:
CryptonX
does any1 know if t135 fi has cdi or the ecu do the cdi job too also where the cdi is located tnx
also how it looks like
CryptonX
yeah i finaly found it :) but i think its wiring is defferent than yours guys
ill post some pictures to see and tell me if its the same
goff_d_p
nope!! thats a different cdi, thats an FICDI. it's got a simaler function as our cdi, except you have the FI engine,
medangmru
HELP NEEDED:
TQ for the advice...
After 2 1/2 months using cdi BRT I-Max...i was twice accelerate my LC to the speed of 165km/h while in gear 3 ....using the sprocket combination of 38-16 (415H ) 8) .....i quite afraid it will harm my engine ...but i tried it twice just for testing purpose as using this cdi ..no rev limiter or cut off...
trevor
hi
im using BRT Smart i cdi. its rpm is adjustable up to 16,000. there's also an adjustable panel indicting the temperature (degrees centegrade) although i don't know how to adjust it. it is really excellent...almost no limiter at all.
second gear could reach 90kph.i just don't really know the proper adjustment..ill show some clip next tym.i think if it is properly udjusted it could probably run faster on hte road.
thanks
nkamri
hallo.. to those malaysian riders.. wanna ask u something; should i change my BRT CDI (Dual Band) to REXTOR??? is it worth?? or same??
Depends on your modification specifications bro..
For standard Carb it is better you use Rextor..
And if you want it to go faster than stock..
You have to switch to another exhaust..
For hi budget modifiers I suggest you use yoshimura..
But if low budget get yourself Nob1 SSS..
Nob1 sss exhaust imitates the standard sound of T135..
For the prices exhaust is RM170 and above, Rextor Cdi Rm450..
If Brt around RM250 from a sale person called Tapau in Kom135.com..
Well Rextor more worthy than Brt actually..
Depends on the rider..
More power means you need to master your control..
And before I forgot..
Does anyone know how to set up the BTDC on certain CDI's..
I'm having a huge confusion about this BTDC thing..
Well I am sharing my opinion in modifying The T135 Lc..
Main thing to be consider is fuel, air and ignition..
Exhaust system and transmission drives..
As well as weight of rider and radius of tyres..
Am I right??
wpt4205
CarroTT said:
ooiiii, i no master lar :(
harlooo glowplug
do u play rc cars ?
just wundering
master:
please help me regarding my bike.....i already increase my stroke by 3mm, my problem now, my engine sound like piston knocking eventhough i did add another 1mm gasket to my engine block and modified around piston sleeve in order me to install oil seal....what should i do now
ialso play rc car my car is yokomo GT-4w nitro powered :mrgreen:
Draven0312
Get the wiring diagram of FI CDI forv easy reference. It has lots of pin/connector
I have same model of crypton x and i have BRT racing cdi but its for carb model can i use brt to my bike with fuel injection model can you give advice if there is a way how to convert....
