of coz u can reach to max..but power supply not enuf may be u should change actuactor to bigger ( i call it cutout) hahhaa)Glowplug said:I had my stator modified now CDI not battery operated but power to lights not enough. But can rev up to max.
Dude what Cdi you use...Glowplug said:I had my stator modified now CDI not battery operated but power to lights not enough. But can rev up to max.
Glowplug said:Yes Car it's a car but the thermo sensor fits and on KIA you dont need electronic gadgets to run the fan from thermo sensor just like the on the stock T135 where it uses the CDI.
I also used it to my FZR 400 and it works great.
how is the modification done?CarroTT said:How much does the KIA pride sensor cost ?
i wunder wat KIA pride is called in malaysia . . .
i made a switch to on/off the fan manually, very simple to do
Tq dude..plz be quickGlowplug said:Tsunami - I will give you final setting of jets once it is set now, still some leaness at top end.
Refuree I will send diagram, I will work on it first.
CarroTT - sensor here is about USD 20, must choose the small one with stamp 104 thats the cut off temp. Ok might as well take picture.
Give me few days
Cheers
