sixty-thirty
Tried all the needle clip positions but that problem will not go away.
Then you need to lower your PJ. Did your piston size is 57mm?Tried all the needle clip positions but that problem will not go away.
yes 57mm pistionThen you need to lower your PJ. Did your piston size is 57mm?
Your piston is to small for 28mm. My previous setup is like this. Even the plug color is correct still have some sluggish part. Try use small pj if there is problem in starting. Result in this spec is same like standard spec with bigger carburetor.yes 57mm pistion
PJ size is 30 main is 110
how small ? 26 ? 28 ?
what carb size for 57mm piston ???Your piston is to small for 28mm. My previous setup is like this. Even the plug color is correct still have some sluggish part. Try use small pj if there is problem in starting. Result in this spec is same like standard spec with bigger carburetor.
24mm maybe suitable. Didn't try because I upgrade my block size to 62mm...what carb size for 57mm piston ???
Hi, just want to ask hm is your Gas consumption per litter?ive read that
165cc engine (60mm piston)
Using Keihin PE 28 Carburetor
needs a pilotjet 40 and the mainjet 125
Got another info:
specs:
60mm 165cc bore kit
open pipe
racing cdi
racing coil
Keihin PE28 Carb
pilot #40 or 42
mainjet #112/115
stock 135cc bore
Keihin PE28 Carb
pilot #38
mainjet #112
try 35pj 118mjHi, just want to ask hm is your Gas consumption per litter?
I'm on
59mm spec-v (stockhead)
Keihin PE 28 Round slide
PJ 40 MJ 120
Open piep AHM M2
Gas consumption is at
24.28 km per 1 litter.
Can some one help me on how to lower my gas consumption without getting on the LEAN side?
Dear sir.. Traxxas, i want to install original TPS with other carburator?? what should i do? what kind of throttle cable did u use to operate the two item at the same time??hi guys
anyone of you have succesfully rejet a big carb for our bike?
can you post your
-stock 135 or big bore?
-carb model and size and
-mainjet size
-pilot jet size
we need to complite jettings sizes on each carb so that we can help each other
actually Sir Traxxass already made that Poor Mans TPS tutorial where you could still use your TPS even you are using an aftermarket Carb. You'll just still be using the original cable.Dear sir.. Traxxas, i want to install original TPS with other carburator?? what should i do? what kind of throttle cable did u use to operate the two item at the same time??
Thanks bro...actually Sir Traxxass already made that Poor Mans TPS tutorial where you could still use your TPS even you are using an aftermarket Carb. You'll just still be using the original cable.
https://yamahat135.com/threads/howto-poor-mans-tps-mod.4737/
Salam semua..
Spec sy:
Moto lc135 4speed ES
blok 62mm cardinal
Spring valve cms
head porting and skim
Camshaft cms
Cdi brt
Carb uma 30mm
Saiz mj ngn pj berapa yang sesuai
i dont try yet. but motorcycle meter easy to go 140km/hhello bro..may i know whats your top speed with your set up? Thanks
Have you try uma cam sir? same lift 5.8?i dont try yet. buat 140km/h motorcycle meter easy to go 140
uma cam to expensive here. what advantage than cms t2? top speed or pickup?Have you try uma cam sir? same lift 5.8?
What your top speed?Im using uma cam stage 2... daily use only.. power mid to top.. ^_^
