agent*mike
Tama po! pero ano po ba uunahin niyo safety or speedy?oicat said:kse hirap gnun hina kuryente may kaagaw pa!
agawan pa un cdi ntn..
Meron po! yong hi/lo po kasi mayroong built-in relay at magnet ang bulb na minsan dahilan ng pagkasira nito. Hindi katulad ng single beam plainly relay lang talaga, na alam naman natin nakakatulong pa ito sa pagregulate ng current. Kaya pag may kumuha sa akin mas nirerecommend ko mag single beam na lang.2b1ask1 said:bakit kaya dun sa mga nakakausap ko lahat sila sinasabi na pangit daw ang hi/low HID?parang madali daw mapundi, may basehan ba ito?
agent*mike said:Meron po! yong hi/lo po kasi mayroong built-in relay at magnet ang bulb na minsan dahilan ng pagkasira nito. Hindi katulad ng single beam plainly relay lang talaga, na alam naman natin nakakatulong pa ito sa pagregulate ng current. Kaya pag may kumuha sa akin mas nirerecommend ko mag single beam na lang.2b1ask1 said:bakit kaya dun sa mga nakakausap ko lahat sila sinasabi na pangit daw ang hi/low HID?parang madali daw mapundi, may basehan ba ito?
napakabit ko na sir ung HID ko,,nagpalit lang ako ng battery, kase 2 years na ung stock ko. ung Motolite na may tubig..so far ayos na, battery operated na pala pag nag HID..ronnelmarc_21 said:@rhoitol--paps ok na yang diagram mo it will work,,,ang coil ng relay mo can be connected to the wires that connect our stock bulb but its AC and make sure na kaya e-drive ang relay...check the relay specs.
@agent*mike --- are u sure the relay/magnet could affect the life of HID bulb/kit?..where is the magnet located?,.in the relay side will create electric/magnetic field in the coil that make the switch "toggle"..relay is similar to our ordinary switch,they just differ in control,.
switches--mechanical control(by our finger) ;;relay---electrically controlled
@gigolo---ohh really???pano gagawin ng mekaniko mo yan?..100% sure na hindi ma dscharge battery mo if the charging rate is faster than dscharging,..or ur battery charger has higher current/voltage rating than the HID consumed...you can boost your charging by removing regulator but doesnt guarantee wont dscharge ur battery...gigolo said:meron pang isang way para hinde madischarge batery mo tol may gagwin lang sa wiring kahit hinde past charger gamit mo sulit.. u can enjoy ur HID kahit babad.. if u want that text nyo ko samahan ko kayo sa mekaniko ko walang problema dun.. 09165911374 / 09232846755
yun siguro yung ginamit sa ilaw ko..gigolo said:nop! its not re-wiring papsi. mahirap i explain here much better na subukan mo kasi yun ang ginawa skin. b4 kasi naputukan ako ng batt kasi natuyuan ng tubig.. pero since then na pinag aralan yun sa wiring so, hinde na nag discharge and kahit ibabad mo pa HID mo walang kaso yun
kahit stock rectifyer ang gamit pwede... 100% yun ilan palang ang nakakaalam ng sikretong yun...
