try to tighten the screw to which the elbow of the pipe is mounted on the engine.. if unsuccessful, try to put gasket or sealant to the elbow before installing.. if still unsuccessful, try to adjust a/f mixture.. HTH..paps, i've already blocked my AIS but i'm still getting backfires out of my pipe. what could be the cause of it? how will i solve it? i'm using nob1 3bold series. thanks!
thanks sir. i'll try that when i have time. thanks again!try to tighten the screw to which the elbow of the pipe is mounted on the engine.. if unsuccessful, try to put gasket or sealant to the elbow before installing.. if still unsuccessful, try to adjust a/f mixture.. HTH..![]()
NP bro.. using open pipe/power pipe sometimes backfire occurs specially at engine break.. i think is normal if it happen sometimes but if it happens most of the time, then its a different issue..thanks sir. i'll try that when i have time. thanks again!![]()
i find the vibration as a normal thing.. but not to much.. better to check on every bolt and nut, keep them tighten..i tried it and gain some power, but i can feel the irritating vibration, would you pls help me guys on how the vibration disappear?
because im scared to remove my radiator...gr..pls pm me...tnx..
so confusedup up upis this mods diferent from this one?
http://www.yamahat135.com/threads/some-proven-tips-and-tricks-for-t135.547/
especially number 3?...
naglibug ko...so confused
Nope my bikes clear as crystal. can't see anything and I've done thisif you condemn AIS,
is the smoke from the exhaust will be
more visible?
sir traxx share us how it's done! informative topics!Theres a better way of removing the AIS. no more tsinelas or slipper mods...
