REMOVING THE BALANCER-Good Or BAD??
big poppa
:?: Hi all! Need to get your opinion of the Pros and Cons of removing the Balancer (behind the Clutch). A friend of mine took the liberty of removing some parts of the y sniper's balancer and replacing them with spacers to minimize weight and improve power. Iam pretty sure that Cons will outweigh the Pros. Im just in a panic and rushing for a reinstall procedure as Im beginning to here noises from the Engine.. :(
big poppa
Well it works as the engine has less weight to carry, specifically the Crank shaft.. you could feel the surge of the power right away from every shift in gears.. this, in tandem with other mods will definitely make your bike faster.. but, I have fears that this will in turn have a toll on the Crankshaft, as weight will be uneven.. I Think Im starting to feel noises already huhu
Mas Catoer
you're right.
The balancer weight was calculated prior to the installation.
So, any mod by reducing or removing it may end in any problem due to uneven weight.
badrulz
hi guys,
just noticed ur talking about the balancer at the handle bar here, i lost mine in an accident recently and indeed it kinda felt ur bike is faster after losing it hehehe. but now i'm lookin for one. really hard to find it in local store. so can anyone help me pls. or even recommend a better brand maybe :oops:
rudduan
to badrulz this topic is not discussing about handle's balancer...its about engine's balancer....
X Project
Removing the counter weight/ flywheel/ balancer or however you may call it, will sure have an excellent effect on the bike's bottom end to mid range performance if you're willing to sacrfice the reliabilty of your engine especially if you take racing as your first priority... But I cannot stress enough the effect on top end as it is easily affected since the inertia is lacking forward motion force to maintain and keep the bike from achieving it's top hence top end suffers but can be countered by sprocket combi... I'll tell you, in the long run you might feel the bad effect or the downide of this mod as an imbalance engine will, slowly but surely takes its toll on your crank left and right side affecting the connecting pin, transferring the stress on the rod and eventually a change of crankshaft assy... The magnet and the idle gear was evenly balanced to the counter-weight when it was installed originally... Hope you get the point dude... If someone has any comments, questions or violent reactions, please, feel free to shoot me an email and I'd be more than glad to answer you brothers...
X Project
For precise balancing with the counter-weight removed... You need to weigh the magneto, idle gear assy or the left side load on the engine and the counter weight on the right side then you can proceed with the machining for lightening procedure... After all these crazy things been done, if you have some spare bucks to burn, then I suggest the dynamic engine balancing for an excellent, superb and unmatched engine performance... Satisfacion guaranteed... Hehehe
goff_d_p
considering the topic is about the Balancer, it's not specified about what kind of balancer, so if your talking about the handle bar balancer, then your ok to talk about it here, as well as the balancer in the engine. just please be specific about which your talking about.
goff_d_p
TOPIC: REMOVING THE BALANCER-Good Or BAD??
I know that stroker, i was directing my comment to rudduan. His comment was "to badrulz this topic is not discussing about handle's balancer...its about engine's balancer...." which i believe the topic is about balancer's in General.
can we get back to the good or bad about having a balancer now
NACZ
Hi guys..
I also done some work on my flyweel.. But i don't actualy remove it all, insted i just lighten it by using another kind of flyweel..
There also knocking on my engine but that is normal due to un smooth rotation at low idle..
I change it on 1,000 km reading still no bad effect on my 13,250+ km reading on my meter..
But we cant say wat comes in the future.. Haha!!!! :lol:
