yamaha parts underground
if u have budget used the faito swift lining very gud or i lack of budget used the chicken lining
wave 125 and sniper lining is almost the same but not totally fit you need to shave the edges of the wave lininghas anybody tried using hispeed racing clutch set for daily rides on t135, from what i've read it will fit on wave 125 also.
For me, IMHO as long as it's OEM i'm good to go!!! I don't have PLENTY of MONEY that's why i'm so sensitive when it comes to the PRICE of an item.
bro Tammy Oldrie Agasin. i've also replace the oem lining with wave125 lining, the wave 125 lining is thicker than oem stock. just installed everything back in sequence. smooth while riding but rough sound click on shifting gear.. the thin spacer.. in the service manual, is it the cushion ring(7) that was removed... http://s23.postimage.org/amh6cmsiz/clutch_bearing.jpgBTW, i already bought the O.E.M LINING OF WAVE 125, and the thin spacer of Automatic Sniper was removed for me to install the last piece of the lining. For your information guys, one of the linings of AC sniper has smaller teeth compare to other 3 pieces.For me, IMHO as long as it's OEM i'm good to go!!! I don't have PLENTY of MONEY that's why i'm so sensitive when it comes to the PRICE of an item.
your bike is HandClutch or Automatic?pls help! newbie The clutch works well in between gears and taking off. However, when the clutch is pulled in, the rear wheel is still in gear and won't free up. Adjusting the cable tension didn't make a difference as I've tried. The only way for there to be no drive on the wheel is finding neutral. Why isn't the rear wheel free when I depress the clutch? How do I fix this?
up!i have the same problem.pls help! newbie The clutch works well in between gears and taking off. However, when the clutch is pulled in, the rear wheel is still in gear and won't free up. Adjusting the cable tension didn't make a difference as I've tried. The only way for there to be no drive on the wheel is finding neutral. Why isn't the rear wheel free when I depress the clutch? How do I fix this?
thank you very much sir!worn out lining
or
the internal clutch pusher adjusting screw is not properly adjusted
i used oem wave100 clutch lining..
I think tnx 155 lining is much better it same to our sniper lining, HCHow about mine chie? what will i use? lining of 125 or 100?
i willl fit if we use Tmx 155 sir?Im used honda TMX 155 clutch lining for HC classic
