YAMAHA T150 ECU PINOUT - Y15ZR SNIPER MX KING EXCITER 150 V1 and V2
Pin#SNIPER 150 V1 ECU PINOUT (2015 - 2017)
-- [33 Pins]
VSSNIPER 150 V1 ECU PINOUT (2018 - 2021)
-- [39 Pins]
1 *Black: Ground1Blue - Black: Fuel Pump (mass signal)
2 *White - Yellow : FAN2White - Yellow: Radiator fan relay
3 *Blank3Blank
4 *Blank4Orange - Black : Injector (mass signal)
5 *Black - Blue : SGND5Blank
6 *Red: Pulser6Blank
7 *Black - Blue : SGND7Green: To Yamaha diagnostic tool connector (K-Line)
8 *Gray - Red ; AFR8Blank
9 *Brown - White : IAT9Black - White: Mass or Ground
10 *Blue: 5 volts10Brown: 12 Volts (this is positive current after the ignition key is in the On position)
11 *Black - Yellow : GND11Red - White: 12 Volts (this is the standby current before the ignition is on)
12 *Blank12Brown - Red : : 12 Volt too
13 *Blue - Black: Pump13Orange : Coil (mass signal)
14 *Blank14Black - Yellow: Main light mass/ground
15 *Blank15Blank
16 *Black - Blue : SGND16Blank
17 *Black - White : GND17Blank
18 *Yellow: TPS18Brown - White: IAT (Intake Air Temperature) or incoming air temperature sensor
19 *Yellow - Green: Bang Angle19Pink - White: MAP (Manifold Absolute pressure) Air pressure sensor on the intake manifold
20 *Black - Blue : SGND20Yellow: TPS (Throttle Position Sensor)
21 *Blue: 5 Volts21Black - Blue : SGND (mass)
22 *Orange - Black: Injector22Black - Blue : SGND (mass)
23 *Orange : Coil23Red: CKP sensor or also called Pulser
24 *Blank24White: Signal from Speed Sensor
25 *Blank25Black - Blue : SGND (mass)
26 *Light green: K-Line26Black: Mass or Ground
27 *Black - Blue : SGND27Black - Green: Mass or Ground
28 *White: Speed Sensor28Blank
29 *Brown: 12 Volt29Light green - Black: To the speedometer
30 *Pink - White : MAP30Black - Blue : SGND (mass)
31 *Green - Red: EOT31Yellow - Green: BAS or Tilt sensor
32 *Blue: 5 Volts32Gray - Red: O2 sensor
33 *Black - Yellow: Head Lamp33Green - Red: ECT (Engine Coolant Temperature)
34 *34Black - Blue : SGND (mass)
35 *35Blue: 5 Volts
36 *36Blue: 5 Volts
37 *37Blue: 5 Volts
38 *38Blank
39 *39Blank
