Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
erhick28
try this sir, from your a/f screw, 3 turn as your base line (from close position), then gradually turn the screw clockwise 2 1/4 turn or more turns and notice the rpm increasing while you turning the screw. you need to reach the highest rpm and try to rev your engine until there's no hesitations (pupugak-pugak). after that spark plug reading... hope it help...
thanks sir.. ill try it..
  • Like
Reactions: Gie
Please help also MASTERS. My current set are as follows:
UMA SUPERHEAD (no head works)
62mm UMA Block Forge Piston
30mm UMA Carb (i dunno the jettings)
UMA Quick throttle
1st - 5th gear may sinok po :( kelangan High Rev lagi. Black po SP, tas every after 3days or 4days, ayaw na mapaandar po kasi basa ung SP. And also, i think their is a problem with my STARTER...cannot start with electric (push) starter (sounds TIK TIK TIK pag pindot ng PUSH Button). Can i just replace the "brush" or do i need to buy new one (UMA STARTER) (but very expensive) :(
jefplacido
UMA Quick throttle
bro di tlga gagana push start mo naka 62mm ka AFAIK
need mo uma starter
adjust k ng a/f mixture
try mo 2 turns then adjust2 like bro grix said
jangbest
please help how to proper tune uma 28mm carb how many turns. my set 57mm, bigvalve pnp, k1cam, vvspring.. when cruising theres a "pupugakpugak" sorry dont know that in english.. but when in full trottle its good..
Uma Carb are hard to fine tune ... AFAIK ...
cubes
pabulong naman ng jettings mo
ok na pres:dance::D:dance::D
jan hehehe bkt kya sa 26mm carb q na nibbbi binabaan q na mga jettings over feed padin black padin xia.. 110/38 ang jettings now. 2 turns A/F need pa ba mag bawas? mga masters?
Ejay
need help masters
stock bore/stroke, keihin pe28, jvt valve spring, rcdi, 110mj 35pj, air screw 1 1/4 out
i already test it but when i twist 3/4 to full parang kinakapos nalulunod sya lalo na kung low rpm sya! help help
Gerry Jaloro
need help masters
Plug reading gawin mo bro... kapag maitim rich kung puti lean, dpat rustic brown to light brown...
mac kevin
need help masters
u have problem with the small (pilot) jet only... experiment it
maky
Need help.
Bakit mc ko purut sa menor na takbo pero kapag taas rev ok na. Gamit ko 120mj 4k engine 20pj stock
Stage 2 gamit ko and stock carb. Wala parin kape na kulay sa SP. White parin kulay
Cerberus
Any OKO speed carb 28mm pe user here?.. Share your jettings for 160cc..im currently working on mine.. Currently on 45/110.. Still cant achieve perfect burn even idle mode. But the performance is ok and fuel consumption is good too..thanks for those who cn help me..
JapSpeed
sir if you don't mind.. what's your gas consumption with 160cc?
