John Jordan
Recommended ba ang 32pj at 112mj sa 28mm na stockbore? Superstock set up. Having a rich mixture with my 38pj and 112mj.
try 35pj & 110 main jet..Recommended ba ang 32pj at 112mj sa 28mm na stockbore? Superstock set up. Having a rich mixture with my 38pj and 112mj.
copy sir jap problem is lang available na 35pj. try ko na lang ang 32pj. tnx!try 35pj & 110 main jet..
i think your mj is too small current jettings are good for stock bore... so you need more mj on it... IMOGood evening Masters need help here please?
Current Set:
62mm bore up
Stock head, pnp, stock vv, jvt v spring,
K1 Rcam,
swr 28mm flatslide, mj 110, pj 37.
still in break in period.
Is anyone there experience using this brand of carburator. please give advice in jettings and a/f mixture settings.
every little info will be highly appreciated many thanks in advance and Godspeed everyone. Ridesafe
Thank you very much boss Japspeed, a how about the gas consumption sir? if i change to bigger mj? and a/f mixture sir if you have any idea?i think your mj is too small current jettings are good for stock bore... so you need more mj on it... IMO
change your mainjet to 115 sir.. nakakatakot yang mainjet mo... mabuti pang mag over feed ka kesa under feed.. masisira engine mo nyan//.Good evening Masters need help here please?
Current Set:
62mm bore up
K1 Rcam,
sa plug and play na vixion nasa 110 to 115 yng main jet.. basihan mo na yan. nka 62 bore ka.. just try different mj.. trial and error ang palaging sinasabi ng mga master natin dito..change your mainjet to 115 sir.. nakakatakot yang mainjet mo... mabuti pang mag over feed ka kesa under feed.. masisira engine mo nyan//.
laki ng pj paps..Current setup:
Uma 62mm
Uma Racing Cam
NGK G-Power plug
Keihin PE 28 (velocity stack)
120MJ 42PJ
Leo Vince SBK exhaust
Current setup:
Uma 62mm
Uma Racing Cam
NGK G-Power plug
120MJ 42PJ
Nope sir, im using brt powermax dualband directly bought at Bandung (indonesia) as in singapore theres alot of this fake brt cdi. Plus i also change my coil to yamaha yz 4ss ignition coil with ngk g-power spark plug . my mj is slightly bigger 120 because i like to rev all the time so i played safe. My plug burn so far was tan color which is gd. Ohh and btw i jz tune my carb with 1 1/2 of air screw. I just change my racing cam to rextor.r cuz hv higher stroke 6.2 if im not wrong. Hope this help.. For pwk28 carb i hvnt tried yet. Its so ex in here.. Lol !Good pm Sir Ojie just wanted to ask if you use uma racing cdi too? and about the spark plug did you use the original spark plug before you use ngk G-Power plug? because at this moment I am problematic cause of wet fouling of my spark plug resulting in hard starting, am using 62mm bore too but not uma, swrflatslide 28mm 37pj 110mj still not changing the mj as the other concern member adviced me to change into bigger mj but for now my gas consumption and spark plug analysis resulting in rich condition. I already ask my mechanic to tune my carb but i still have the problem. please advice and i hope some other new member get usefull information in my post here Godspeed Ridesafe to all.
good day sir,Good evening Masters need help here please?
Current Set:
62mm bore up
K1 Rcam,
