Snipespy
ok na yan paps .. stage1 set.
pero mas lalabas power nyan kung install kadin cams,
Pre pede pa ask taga cdo ako walang ganyan na brand pre pede ako manghingi tips trusted sellers and total magasto ko dito and saan mabili?
Vixion valve spring-??
Cams-??
Rextor cdi-??
Tnx..
rich_havens
Tns bossing so rextor cdi and vixion valve spring yan pa kasi ma afford ko eh oki na ba yan?
common kasi pag nag palit ng valve spring na o open head so para makatipid sa labor dinadamay na rin pakabit ng cams :)
but like you said if yan afford mo go for it... but if your planning to upgrade more... save your money... buy the parts at time.. then pag complete na saka mo ipakabit lahat...
rich_havens
Cams-??
Rextor cdi-??
Tnx..
why do you need to change not only one part when you change the other? beacause you need to match it mathematicaly...
RCDI --- sa pagamit nito matataasan mo limit ng RPM mas makakabirit ka
VALVE Spring -- stiffer valve spring ang need mo since nag RCDI ka mas mabibirit mo bike mo possibility na mag valve floot kung malambot valve spring... need mo ng valve spring that can sustain and match sa pagbirit at maiwasan ang valve float.... bakit iniiwasan valve float pang nagyari ito.. tukod ka somehow parang stock up or may delay valves mo
CAMS -- para sa response ng engine... mas may power mas mabilis ang cycle ng engine... usually sinasabay ito pag nagpapalit ka ng valve spring... if you may ask me what brand... i will go for kawahara... CMS, yy pang.... there are cams na nauupod... i dont want to mention it na kung anong brand... im using yy pang cams tried and tested had it installed in my bike since 2012...
CLUTCH Spring - sabi nga para mas may damba sa take off... sa change gear
REJET - a little bit rejet on stock carb...
jangbest
why do you need not only one part when you change the other? to match it mathematicaly...
very well said Idol
Dropper
mga boss, pag nagpalit ka nang cam kahit stage 1 lang.. need ba talaga mag palit din timing chain? or stay stock timing chain lang. Baka kasi mag iba ang timing pag nag shifting. salamat
rich_havens
in my experience and as far as i know no need naman... im using stage2 cams... but if its due for wear and tear kindly change it to avoid hassle...
rich_havens
Any tips for parts that i should buy first??
first... set what you want for your bike to what extent
2nd... ask a skilled a trusted mechanic, or if your know how to build your bike it will be an advantage
3rd... plan whats within your budget
4th... buy parts that you can, collate it
5th ... ready your budget for labor
Snipespy
Sir if stock bore lang po gusto ko tapos gusto ko tuparin yung binigay na tips ni trax magkano ang gastos? Ung rcdi,cams,valvespring,tsaka clutchspring.
tabi1
PLUS: if your going to open your motor, it's better to do all of the work at one time then keep changing one part at a time so your not wasting time and money on a good mechanic. Think like the US Marine Corps - One Shot One Kill - Hoorrrrrrrrrrrrrrrrrrrrrraaahhhhhhhhhhhhhhhhhhhhhh :D
rich_havens
ito rough estimate: (pwede mataas pwedeng mababa)
RCDI - 3k-3500 Brt hyperband brand
CAM - 2,000 - 3k (yy pang, CMS, UMA, vixion) depending on the brand and seller
Valve Spring - 1700-2k Yamaha Vixion Valve Spring
Clutch Spring - 400-500 CRG Clutch Spring
Labor - depende sa mechanic, yung RCDI pwedeng kahit ikaw lang magkabit but the rest need ng mechanic or kung maalam ka mas mabuti
Snipespy
Paps alam ko out of topic to pero bawal ba underneath sa motor? (Hinde side plate)
rich_havens
pano ang display ng palte mo? may late holder ka pa rin ilalagay? kasi kung underneath ka at di visible sa nakasunod sa u plate mo pagkakalama ko may violation un sa LTO un eh kapag may humuli sau...
