mj viloria
e2 specs ng motor ko..
ask lang po kung ok lang ng mag stroker pin na isunod ko na mods?..
advantage po ska disadvantage?..tnx
heres my spec
rcdi
valve spring
rcams
clutch spring
28mm big carb
heres my spec
rcdi
valve spring
rcams
clutch spring
28mm big carb
pwede
...kung prefer mo stock bore pero naka stroker pin ok din...or vixion plus stroker pin...less gastos lang sa stroker pin unlike using crank assembly...sa gas consumption,80-100kph speed nasa 40-45km per liter consumption..ok na ba un?
